DMeN Z »
https://forums.nicoclub.com/dmen-z-u132244.html
Tue Feb 16, 2010 4:53 pm
May be a little overwhelming...
I have a manual transmission (TT) ready to go and was wondering whether the crankshaft clearance is the same or near-same in the Zs?
Can I complete my conversion without a clutch booster? There is a kit available by CZP without it.
I'll be upgrading the Z with the newer injectors and components ('95 EFI TT M/T harness, 94+ cas ) but I don't know if I'll need to replace my ECU with another since I'll have a different harness. If i wasn't changing years I know I could keep my auto ECU.
With the harness change, what other components must/ should/ recommended be changed? what can be spliced?eg. O2 sensors, air regulator, egr valve, COPs, etc. (from what I read may need to be changed)
Also, for the trans/ alt harness, do I go by the year of the car or the year of the transmission?
THANK YOU x3, You're all far too kind- JZ. Thanks in advance.
Modified by DMeN Z at 12:01 PM 2/17/2010
