vda240 wrote:Im looking to swap a vh45de in my auto s14 Kouki... I have a couple of questions (I searched couldn't find the answer)
1. Will a stock Z32 TT auto trans bolt up right up to the VH block without a adapter plate?2. I heard you can use VK45DE heads on VH45DE and get massive HP increase, is this true or false?3. If I'm going to use Mazworx mount kit, will I have to cut the hood/custom make, or it will have somewhat of a clearance? 4. Also, does VH45 have problems with oil starvation?
Thanks in advance guys.
1. No2. Not Sure3. Probably not as I worked with them for a prototype of this for my Z32:
zer...-of-14. No - Mazworx drag races theirs without any issues / autocross may be different - different forces. If you mod it make sure you end up with enough oil capacity - at least that of stock. I was under the impression the s chassis didn't require oil mods - but I may be wrong.
Thanks,Nick.
