future upgrades are as follows which will lead into the questions...
http://www.konigwheels.com/cat...d=326
and im gettting the 15 inch ones ( $105 a peice
http://www.konigwheels.com/cat...d=137
thought about these, but eh, i dont know. the first ones are my fav color and my car will be saphirre blue
also the 215's wont throw off the speedometer too much . i think it will be like 1 or 2 mph off.
ok i am either thinking of upgrading to the z32 or the q45 brake system. now will the 30mm clear the 15's (not the heliums, the other rims)??? if not im guessing that i will go with the 24 or 28mm (what ever the other is!) . which ones would be better for auto crossing every now and then? more daily driving than anything? hmmm i think that is about it. oh and when i do get the coilovers, do i have to worry about those clearing too? say if i dropped it about an inch or inch and a half even two inches?? also just to add to the plans... im getting the sr20det redtop. and 4point roll bar. ok that should be it, plan on getting the tein inner + outer tie rods, adj tc rods, and sus tech sway bars.... yup that should be all.
i wouldnt mind having the 30mm upgrade, but if i can i would rather go for the 26mm(?whatever?) upgrade but which one. and arent the 30mm ones made from aluminum? and the smaller ones from cast iron? are the q45's cast iron too???? or are the aluminum?
ok if anything else i will ask later
thanks a lot guys
