Is this the first place you've looked? What else have you done to try and fix the acceleration problem? I'm not sure you can really "clean" it. If it's not working properly, you'll probably get a code.
Component Description:
The mass air flow sensor is placed in the stream of intake air. It
measures the intake flow rate by measuring a part of the entire
intake flow. It consists of a hot film that is supplied with electric
current from the ECM. The temperature of the hot film is controlled
by the ECM a certain amount. The heat generated by the hot film
is reduced as the intake air flows around it. The more air, the
greater the heat loss.
Therefore, the ECM must supply more electric current to maintain
the temperature of the hot film as air flow increases. The ECM
detects the air flow by means of this current change.
Acceleration
Have you tried cleaning your throttlebody? Sometimes that will take care of it. Take a look at your injectors- dump some fuel injector cleaner in the tank and see what happens. Does it bog at a certain speed, or is it slow regardless of speed? How is your throttle response?
Excessive wind noise
If you don't have anything hanging from the doors or windows, new weatherstripping- I'm not sure. Is the weather stripping OEM? Maybe you've been in someone else's new car, and are paticularly noticing the noise level in your car now.
Noise near the drive shaft
Take a look at the link
http://i1193.photobucket.com/albums/aa3 ... sChart.jpg
