Got the crank pulley and heads off. Took the oil pan off and put a 2"x6" board under the crank to keep it from moving.
The motor has a lot of miles. The timing belt looked great, no wear at all, I think it was replaced not too long ago. The valves, cams, and piston tops show no sign of abnormalities.
Now with my goal of at least 300whp, what should I be looking at? I'll be getting an upgraded headgasket and head studs. Anything else I should be doing?
