nissans13240sx wrote:Hey guy, im pretty new to KA-Ts. My motor is basically compiled of parts I had laying around. Its a dohc with a t25 from a SR, running 7psi/wastegate. I am running stock injectors with a FMU, ARC side mount intercooler with a greddy type s bov. The motor only had 80k on it but I still replaced all the gaskets using stock gaskets. My goals werent big for this car it was just something to have fun in while I am building my RB. Anyway, the point of this thread was so I can ask a few questions.
1) What kind of spark plugs do you recommend? What gap to?
2) Is there anyway to tell what size my FMU is? I got it for free off a galant vr4, there isnt much description besides that its blue and vortec makes it.
3) What should I set my timing to? Is stock spec ok?
1) NGK bkr7e. but they changed the part # and i dont know it off hand. start your gap at .32 and make it tighter as needed do to spark blow out, but at 7 psi i dont see that happening.
2) sorry cant answer that one, I never messed with an FMU. post pics maybe someone can help you.
3) .5 deg retard per psi of boost, so about 4* and you should be fine.
