Couple lighting questions
Jakw
Car: 1993 J30
I got HIDs. Sometimes, the left one will flick on for less than a second, then turn off. I have to fiddle with the switch to get it to come on and stay on, usually by turning it slowly so the left one comes on first, then the right one. Sound like a relay problem, or osmtehing else? All connections are tight for the HIDs.
My battery seems shorter than the bracket is made for, would this make a difference in anything at all?
How do I get to the bulbs in the front corner lights? How do I change the reverse lights? I've been seachign around, but can't find this stuff. Thanks for your help.
Jakw
Car: 1993 J30
Ok, so corner lights have one screw and pop out. Got it.Working on the HIDs, might be a bad ballast. They're under warrenty.That leaves me with the reverse lights.
naladude911
Car: 2001 Infiniti QX4
Get a flat screwdriver, and pry the top of the reverse lights. They should just pop out.
Jakw
Car: 1993 J30
Oh really? Neat. Thanks man.
