Couple important questions (search = nothing)
KATwo40
Car: 1993 240sx KA-T
I have 2 questions.
1. Can stock KADE MAF go blow thru?
2. Can I put washers behind the pass. side of the brake booster to push the master away from the turbine housing without damaging anything?
Thanks!
Jookmasta
answer to question number one is yes. not sure about the washers and brake booster thing.
1WheelWonder
Car: 1991 Nissan 240sx
1. Yes2. I have heard of s13 guys using s14 master cylinders to gain clearence.
Iamjohnhayes
Car: 89 Single Cam Hatch
are s14 master cylinders smaller or just a different design? B/c wouldn't a smaller one mean less braking power? (plus the s14 is a heavier car which would make a smaller mastercylinder kinda of dumb design)
KATwo40
Iamjohnhayes wrote:are s14 master cylinders smaller or just a different design? B/c wouldn't a smaller one mean less braking power? (plus the s14 is a heavier car which would make a smaller mastercylinder kinda of dumb design)
Might be a case of shorter, but larger diameter to achieve the fluid push it needs.
