Well i wasnt sure where to post this, rb section or the vg section? So i decided to ask here. Basically i have read alot in the rb section stickies and learned that the rb's and z32's share alot of driveline parts. I was wondering if the flywheel from a r33 rb26 with awd transmission is the same as either a z32 tt or a n/a z32. I have the flywheel from a r33 and to my suprise the clutch from a 88 z fits, (the white bunny special). Well except for the allignment pins. Other than that the bolt holes line up.
The clutch disk has the same sline count and diameter and all. I have read up on the push to pull conversion and was wondering about this. If they have the same bolt lay out, the 300zx bellhousing conversion may not be necessary for me. Thanks
