240z4u »
https://forums.nicoclub.com/240z4u-u26156.html
Thu Jul 15, 2010 5:46 am
Alright, I am going to put these two things together in case they are related.
1) For some reason my alternator does NOT start charging normally until the RPM's hit a certain level. IE I have to crack the throttle usually. Once I have done that, it starts charging. I have 0 ga wire running to the optima in the trunk and the alternator is new, this happened on the old unit too. I am thinking bad grounding. This wasn't a problem in the past but corrosion over the last 4-5 years could be taking its toll.
2) I am blowing out spark at higher RPMS with the LS coils. New plugs. I figure this is either related to a janky ground situation or I just don't have enough power at the coils and need to install a relay and better wiring for them. The A/Fs look pretty good when this happens.
Any other thoughts here?
Thanks guys.
