Couple comparision questions (ca18de, vrs DET)
burntricer
Car: 90 S13 SR20DET Redtop
is a EFI relay the same as an ECCS relay??
does a CA18DET have a A.I.V control solenoid? if so where is it?
the FCID, can it be deleted? i wont be running AC (does that mean i can delete the AC relay ect?
burntricer
on the de there are 4 pins for the cas
they are listed as the crank angle sensor reference signal x 2and the crank angle sensor input signal....
on the DET its listed as the 1 degree input180 degree input1 degree signal180 degree signal
sooo lost
boost_boy
burntricer wrote:is a EFI relay the same as an ECCS relay??
Yes to everything! On the CA18DE it's bolted on the same side as the RWD.
Dee
boost_boy
burntricer wrote:on the de there are 4 pins for the cas
sooo lost
Are you wondering if you can use the DE's crank angle sensor? The answer is "Yes"......
Dee
