Couple 3rd gen questions
3rdgenmaxi
Hey guys finally signed up always been on nico though just reading when im bored and stuff haha but my question is would the 6 spoke wheels off of the 4th gens fit on th 3rd gens because i found a set for pretty cheap i was going to pick up if they fit. Also i read that a short ram intake from the same gen accord would fit on the max is this true or not?? Thanks in advance for all your help
MaximA32
Pretty sure the bolt pattern is the same but I'm not 100% sure. As for the intake question, compare the part numbers on the two and go from there!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Yes, all 5-lug Nissans use the same lug pattern (5x114.3). They'll work.
3rdgenmaxi
Okay thanks for that i thought they had the same bolt pattern i was just double checking!
Chris92SE
Car: 2017 Infiniti QX30
2003 Nissan Pathfinder LE
Stock wheels from all Maximas, G35s and 350zs will fit the 3rd gen. But, if they have the stock tires, the tire sizes usually won't work. Technically, some will fit in the wheel wells, but the speedo will be off and it looks really 4x4.
I have seen G35 coupe 18s, 350z anniversary wheels and 18 inch 350z track wheels, along with pretty much every kind of Maxima wheel except 7th gen. I have also seen 3rd gen Maximas with 18 inch Murano wheels and FX35 wheels.
I have a set of 17s from a 2005 Maxima. I painted them, but I need to buy tires for them. I know some other guys that have run the same wheels and they look nice.
These are the ones I have:
