xyster »
https://forums.nicoclub.com/xyster-u1869.html
Mon Jan 27, 2003 7:39 am
I'm having a couple problems with my 92 240SX 5spd with 151k.
1) the clutch system doesn't seem to want to hold pressure. I replaced the master cylinder, which was only 2 months old, and it seems to be slowly losing pressure again. It shifts fine, but the pedal only returns about 3/4 of the way up. The clutch pedal completely disengages...it seems that other 1/4 is freeplay. the slave cylinder is also about 2 months old, and neither cylinder is leaking. I've bled it multiple times, both at the slave and the junction box.
2) It bogs between 3k and 4k rpm. It's not a continuous bog, just "blips" of power loss, and only in 2nd-5th gear in that certain rpm range. The spark plugs and fuel filter are about 2 months old, and I replaced the fuel pump yesterday. I also checked the tightness and gap on the spark plugs. I'm replacing the in-tank fuel pump filter tomorrow, because the new pump makes a slight whining/whirring noise every so often, just like the old one did, though less often. My guesses are MAF or plug wires, because both were on the car when I bought it 6 months ago, and I have no idea how old they are, though the wires look fairly new. It has a Injen pop charger intake filter, btw.Thanks for any help
Xyster
