Coupe wheels for '04 G35X
Last Ride
Car: 2004 G35x
Hey all--My search results offered little in the way of advice, so I figured I would start a new thread. I have an '04 G35X with the stock 17" rims on it. I really like the look for the 18" 7-spoke or the 19" split 5-spoke designs that are available on the coupe. Is it possible to fit these wheels on my car? I have been told to shop for an offset 35-38 mm all the way around. Would this be accurate? I know the coupe traditionally comes with staggered offsets, so should I be shopping for two sets of front wheels or two sets of rear? Thanks for the help.
Bryan
I'm pretty certain you're going to be looking for a set of 4 fronts or rears. The 18's are non-staggered, but I believe the 17's and 19's are.
Although, the BEST way to check is to go to a dealer (or find a local with the car you want the wheels from) and just do a test-fit.
Distregard the offset numbers, as tire size will play a role here, as well as appearance - You may WANT the wheels to sit more flush to the sides.
