tollboothwilley »
https://forums.nicoclub.com/tollboothwilley-u74535.html
Mon Apr 14, 2008 7:42 am
ya, that happens sometimes
Anytime I'm working with bolts that are subject to water/rust I use WD-40 before I even try to get them loose. It will save you the hassle of getting mad and stripping bolts.
If your nut is stripped out with no hope, you're gonna probably have to cut off the bolt, drill it out, then replace with another bolt and nut.
Probably easiest to drill out the bolt side and smack it loose with a hammer IMO.
