Coupe electronic Speedo
RagingPanda
Car: 78' 280Z
I was wondering if you can put the electronic speedo in a fastback. I think it's a nifty little thing and I know that only the Coupe S13 has it and it shouldn't be impossible to put it in a fastback right?
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
yes, it is possible, they are kind of a pain though, they tend to go out.
what you will need is the digital cluster, and the wiring harness for the cluster (pretty easy to do). and if you want the HUD you will also need the HUD assembly that projects the speed onto the windshield. (you will probably want the little cover that goes on it as well) also, if you don't get dash from a car with a HUD you will have to cut some holes in yours for the HUD unit.
also, despite what some people will tell you. you don't need the glass that is specific to the HUD (that has the section of glass with a tint that helps in reflecting the speed) you can run without it, and/or you can just get some tint film, cut a small square out and stick it to your windshield to help reflect the light.
hope this helps, if you have any questions drop me an e-mail at ceniack@*REMOVEFORSPAM*cox.net
