Coupe Drop??
BROSE391
Car: '09 Nissan Altima Coupe 2.5S
Is 1.8 the lowest that you can go with these cars, somebody please open my eyes to this situation im sure someone lese has done more research out there the i have...
How much does your wheel camber in when you drop it with 1.8 springsNe Idea?Ne Other options....Could get hick with it and just cut the stock springs
-J'Brose
bunda4th
Car: 2008 Nissan Altima Coupe 2.5S 6MT
That is how low I am with BC Racing Coilover (all the perch is lock up and rear have 1 thread left). I am on 18x8.5 and still need to get an alignment done.
I already bottom out so I would say that is the lowest you can go.
Heels1010
Please do not cut the stock springs. You will regret it when your suspension falls apart. Best kit in my opinion for the money is the eibach pro kit. Designed to work with stock suspension does 1 inch drop in rear and 1.5 inch drop in front. Most guys on here have the eibach drop. There are not many options out there yet for dropping.
All depends on the wheels you have too. If you run stock wheels a 2 inch drop would be insane and not recommended as a daily driver since u would bottom out all the time. The coupe is already pretty low to the ground as is.
BROSE391
Thats what ive been told how much did you spend on your coil overs and where could i find them?I couldnt even find Altimas on thier website...Do G35 coil overs fit or somethin, coilovers are deff the way im looking to go.
Modified by BROSE391 at 2:42 PM 9/11/2009
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
Heels1010 wrote:The coupe is already pretty low to the ground as is.
That is very relative. Sure compared to a truck the A/C is pretty low, compared to other small cars its par for the course. And compared to sport coupes its pretty high.
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
BROSE391 wrote:Is 1.8 the lowest that you can go with these cars, somebody please open my eyes to this situation im sure someone lese has done more research out there the i have...
-J'Brose
I haven't got an alignment but the camber is not too bad with the Eibach pro-kit. Although my tires are wearing on the inside in the rear a bit...
Don't cut stock springs, thats just retarded.
The reason why it doesn't go that much lower with springs is because if you look up into the rear wheel well you will see that there is not much room left. It may seem like a lot but it's not. If you hit a bump or a pot hole, any lower and it coul rub pretty bad up in there. The coilovers are certainly worth it if you want to run a lower drop because they're stiffer and don't cause some much travel to happen when you hit a bump.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Welcome to the club!!!
http://forums.altimas.org/zeromain is the link you should bookmark!
All the info here is in its proper section (for the most part)... Please try and post in the correct area!(this type of discussion is in the "Suspension" Section.... take a look over there, all the answers are within!
The search button works too, and we are always here to help you out! (again post in the right section if you can, if you arent sure, dont worry theres no beatings issued!)
bunda4th
BC Racing Coilover i got from Circuit Motorsport for 999 shipped. When you are on their site you have to search bc racing or email them to get it.
Desire1314
Car: Altima Coupe 3.5SE 6MT
you can always wait for Tein to come out with their coilovers...if your not in a hurry to drop
Heels1010
I am just waiting to see what winter will be like with the car dropped on stock rims. First snow storm should suck big. Also keep in mind if you put a body kit on the car it will be lower. Many people are having problems with their front lips with the eibach drop and bottoming out.
