coupe driver door
All things Altima Coupe.
Kasper08
Car: Car in the Avatar
does anyone else have a problem closing theirs, i'm pretty sure i pull it just as hard all the time but sometimes it just doesn't close all the way and i have to do it again . i'm just wondering if i'm just being a tard or if someone else has had this problem
sewright
Do you have the same problem is the windows are down (even a little). My jeep is so air tight that happens. Window down and the door crashes shut. Who knew, a airtight jeep.
Kasper08
lol, i gotta try that out and see if everything closes correctly
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Trouble pulling your door closed? Maybe you need to lift some weights
Can't say I have the problem. It's not that heavy of a door
Kasper08
SHIFT_COUPE wrote:Trouble pulling your door closed? Maybe you need to lift some weights
i left myself wide open for that one :-)
guitarmn07
Car: Azure Blue Altima Coupe 3.5SE Charcoal PP
I've noticed that my passenger door whistles. I open it to close it again and the whistle goes away. I didn't slam it shut or anything tho.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
I took my doors off and installed safety netting like the ones you see on Baja vehicles
