countersteering problem
Nissan dominates the drift scene - Always has, always will.
mdn180sx
Car: 91 240sx
ok. whenever i try to counter steer the back end just flips sides and i change directions. i cant get the car the continue in the same direction while countersteering. i dont know what im doing wrong. any advice will help.
Joe
sounds like you arent breaking traction.
how are you initiating the drift?
mdn180sx
Car: 91 240sx
clutch kick. i usually go out after it rains. are there others techniques that will work better for a low power KA w/o an lsd
Joe
wait longer into the slide before you countersteer then. try this
stay wide open throttle, slight turn into the corner, clutchkick, wait for rear to come out more, then let the wheel slide through your fingers for countersteer. make sure you STAY ON THE GAS.
mdn180sx
Car: 91 240sx
thanx. i'd read in a few other posts not to ever let the wheel spin freely but, to always manually countersteer. does it really make any difference?
Joe
you need to be stupid fast to countersteer as fast as the car can push the rear end out.
personally, i always let the wheel slide through my fingers. dont let GO, let it slide.
Dori Dori
Car: Cars of course
^agreed.
virus77
Car: 95 S14, 71 240z, 97 e320
Yup, let the steering wheel slide through you fingers till you catch your angle, grip steering wheel, keep the rear tires spinning and hang on for the ride. (by hang on for the ride i mean you have to adjust throttle and give slight steering adjustments from the point you gripped the steering wheel at to maintain a proper line). It would be impossible to manually countersteer.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
It's not impossible to manually countersteer...Think about it guys. I'm sure you're drifters (Kamin, I KNOW you are)
You're just not thinking about it. When you enter a deep corner that takes a shallow entry (hold it straight-ish before corner entry) do you just let the wheel slide all the way? No you turn it back and hold it.
For a deep angle drift, then spinning the wheel is the way to do it. Sometimes you can encourage the wheel along by directing it..."Throwing" it, if you will.
Generally, if you're snapping back, you're not sideways enough. Exiting your slide, remember to steer back straight or you'll snap and spin.
Dori Dori
Car: Cars of course
Nobody said to let it slide back all the way...just enough to where you think you're countering enough. One can release again if its not enough or adjust into/away from the turn if its too little/too much. For high angle, fast drifts (which is generally what people are talking about when mentioning drifting), I agree that it's more or less impossible to counter fast enough without letting go of the wheel.
EazyBreazy
i have never been able to steer the wheel as fast as i can throw it. especially not in the hachi i had in japan, that as$$ end would come out in a hurry.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
MainEvent212 wrote:It's not impossible to manually countersteer...Think about it guys. I'm sure you're drifters (Kamin, I KNOW you are)
Agreed
240SicknessX
Car: 96 240 SE
something that helped me with over countersteer, try straitening out the wheel eariler. if you are learning you dont have a good feel for how much tracksion the car has and how quick it will be gained back. Genrally after the apex you will want to start reducing your angle for a smooth exit, not wait until the rear catches grip before attempting to straiten the wheel. :\ dont try to hold the maximum countersteer angle that you can on the drift until the end, try to straiten out eariler, it will prolong your slide and smooth out your exit.
so hard to give specific tips \ tricks ove the internet w\ out knowing the drivers particular experiance.
marshun
open diff right? work on your steering movements and your timing. thats all.
FAST-DATSUN
go to a drift class so the instructor can see what your doing. Many times what you think your doing is different than what actually going on. Check for classes in you area and get help..
Return to “Nissan Drift Forum”
