480sx »
https://forums.nicoclub.com/480sx-u50548.html
Tue Mar 13, 2007 5:29 pm
You dont need any of that stuff to drift. Get a Kazz 2 way LSD befor you get anything, you can pick them up for about 850 shipped on ebay. Just make sure you break the LSD in first. After you learn the basics of how to handle the 240 in a slide you can do your swap and whatnot. Again, you dont need power to drift, especialy if your a beginer.
A SR swap will balance out your car a little beter, getting your weight distribution closer to 50/50 front and rear. The USDM model is a little front heavy due to the iorn block. The SR has an aluminum block and is much lighter.
As for the rest of it its up to you, if you have the cash go nuts. Hope this helps.
