could thicker oil cause lifter tap?
m830a1
Car: 1990 240sx s14 sr20det
1990 300zx 2+2
I was reading a thread on recommended oil for the summer time. It said to run a thicker oil so I changed oil from 10w-30 to 20w- 50 and now their is a tick. could the oil be the cause? The tick is inconsistant and only noticable at idle (WTF?) when i let the car get real hot (200+) it goes away (WTF?).
Emperor_Tha
Try 10-40, I haveno problem winter or summer.
m830a1
1990 300zx 2+2
thanks man, i am going to run this oil into water before i change it. last night i ran it real hard and it stopped. so i guess it has to get hot before you get the benifits of the thicker viscosity.
chad300zx1990
Car: 93 nissan 240sx right hand drive
20-50 is tooo thick. stick with the 10-40, you'll be fine
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
I run 20w50 in mine but its for solid lifters. A always ran 10w30 on the stock setup.
MastaYu
Car: 92 Nissan 240SX SE HB
/thread jack/ ^whats the maintenance like with the solid lifters?
