rb250sx »
https://forums.nicoclub.com/rb250sx-u8777.html
Sat Nov 12, 2005 5:17 pm
So im still having tach problems. I have a S13 with sII rb25. Ive tested voltage at the plug of my cluster and at idle the signal wire is around 6.some volts. checked the ign wire on the plugs and the grd and all are good. ive used 4 tachs so far, the digital one that came out of the s13, an analog one from another s13, the RB tach and a tach that i took out of another digital s13.when i plug the s13 cluster in, the needle wont move at all. The RB tach was out of the cluster, when i hard wire 12 volts to ign and signal it wants to peg to 0 rpms. This tach is out of the cluster howevever and may not be operable. The tach out of the digital s13 cluster has 2 grnds on it, however there is only one connection for ground on the back of the cluster itself. when i hard wire this tach it does the same thing i saw with the RB tach (moves counter clockwise toward 0). Anyway, i know people have been driving around with the stock 240 tachs and just were getting inaccurate readings, but they were at least getting movement out of the needle, am i correct? If someone can help me or give me some kind of technical explanation for what im seeing it would be appreciated.
