skyyred »
https://forums.nicoclub.com/skyyred-u52486.html
Thu Jun 14, 2007 4:40 pm
alright i have a s13 sr20det...every time i gun it, it'll speed up for about 2, to 3 seconds then it will start bucking it idles fine and drives smoth at normal speeds it doesnt buck if i speed up gradually it does it from 90 100% throttlei tried adjusting the CAS and by just moving it a hair changes how long i can gun it before i starts bucking... at one point it ALMOST whent away.....
checked and changed- spark plug- fuel filter- fuel pump pressures normaly- cat- TPS new- maf was checked by a mechanic friend- ground- timing is right even the cas
is there a way i can check it..if its telling the ecu the right thing or can it be my ecu
