Could I use infiniti j30 resistor pack 1993-1997 to run low impedance on rb25?
exodus5547097
Could I use 93-97 J30, 91-96 Acura legend resistor pack to run low impedance on rb25?
Modified by exodus5547097 at 10:36 PM 2/22/2009
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Yes, as long as the resistance per lead is ~10 ohms. I have seen guys use V-6 Honda Accord resistor packs.
Carl H
i have no idea what you're talking about...the j30 does not use low impedence injectors...they use standard sidefeeds.
exodus5547097
Thanks Carl.
Carl H
again...j30s do not use resistor packs.the ledgend pack works fine. i have one on my car.
wawazat8402
Car: 89 Sil80- RB25DET
It should be noted, though, that you do not get the full benefits of low impedance injectors without running an actual low impedance injector driver.
