Could I use an 90-96 NA 300ZX OE Exedy clutch for RB25?
exodus5547097
Indolent
Car: coupe
if the RB25 clutch disc diameter is 240mm, then I don't see why not, because Z32 N/A clutch disc diameter is 240mm
BoostFab
Car: S13cp, S13fb, S14z
na z32 = d21 = rb2*; however you don't want that OEM rate; you will slip it quickly.
exodus5547097
thanks guys!!! Helps a lot when you said slip.
Booztd 3
Car: 1990 Nissan 300ZX TT
exodus5547097 wrote:thanks guys!!! Helps a lot when you said slip.
DXD Racing (South Bend Clutch) makes a few good setups for our RB motors. They're basically NA Z32 sized clutch kits but built for big power....Ive been nothing but happy with my 6puck from them
exodus5547097
Oh yeah, what about RB-Performance clutch? are they any good?
kumasan616
Just ordered mine, 6 puck w/ flywheel. I'll let you know once I have it in and working
blackr32skyline
Car: 1990 JA70 SUPRA / 1983 Toyota Trueno GT APEX
i use an ACT street disk and HD plate it works great.
exodus5547097
what flywheel are you using bud?
blackr32skyline
my spec flywheel works great. i never had any issues whatsoever and i noticed a little quicker acceleration on my rb25 240.
exodus5547097
thanks for the info guys!
Booztd 3
I like the stock flywheel for any kind of drag racing.....it helps a ton on the launch...
