Could i get some comments plz.
gandhi240sx
Car: 1992 240sx se hatchback N/A
Well I have been sanding and prepping my s13 for the past week,i've been researching different ways of painting my car on a budget and due to my severe lack of money i went with the rattle can method. I am doing a krylon flat white. I really dig it because if you do it right i feel it won't look as bad as a flat black rattle can job. So far ive spent about 40 bucks on paint and sand paper. I just want to get some opinions on my method and idea. I don't think anyone has attempted a flat white on a s13 hatch so you might be interested with the results. Ill post some pics tomorrow.
AZ89two4Tsx
Get one of these.
touge_951
yep. thats a really good idea.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Flat white is going to be uber hard to keep clean.
90notch_5.0
Car: 90 Mustang
good luck with the paint job bro
gandhi240sx
Fibre guy wrote:Flat white is going to be uber hard to keep clean.
i know man,i have been painting section by section and when i sand and touch one of the previously painted areas it shows up badly. Thanks for the advice guys.
gandhi240sx
90notch_5.0 wrote:good luck with the paint job bro
Thank you kind sir. I am going to need it,did i mention this is my first time painting a car?
Papi Chulo
Car: 72' Datsun 510
are you going to put any clear on it?
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
My friend sprayed his coupe flat white. supposedly going to get a pearl clearcoat over it...doubtful.
GL
roadboy240sx
Car: I like Nissans
you stole my idea i was gonna go flat white.
anyways lets see some pics cuz i have never seen a flat white 240
gandhi240sx
Papi Chulo wrote:are you going to put any clear on it?
I've considered it, Krylon has a flat clear coat i might try out.
Here's some pics.
Still not done with it,planning to put some more coats on it
Modified by gandhi240sx at 11:39 AM 7/10/2009
Jadesr20det
Car: 1990 NISSAN 240SX
what was wrong with the original paint?
gandhi240sx
I had to fill in a hole on the hatch as well as fill in some dents. I didn't want to ride around with patches on my car. I also didnt like the maroonish color that was on it originally.
keith0486
looking good so far man keep it up. id deffunutly do a second coat on that it will help even it out.
s13importuner7
Car: 1991 240sx
are you doing the door jams and everything? also i have one of those gun holders for spray cans. i like it actually. its kinda silly but its so much easier to use.
Fibre guy
It's not too bad but I would tape it off and bring to a paint shop to do a quick and cheap mildly flattened clear coat. An honest shop might charge you like $30-$50, less if you supply the paint, but you could just hose it off when it got dirty.What I meant about keeping flat clean is that any sort of dust, dirt, tar, etc. will stick to it and be impossible to clean. Hence the flat/matte clear coat. If you don't it might look clean for a month tops.
Jadesr20det
+1 on the clear coat if you dont the car will come wind up looking dingy....looking decent though for your 1st time
slidestyle69
Car: 92 s13
[QUOTE=Fibre guy]Flat white is going to be uber hard to keep clean. [/QUOTE
yes it stains too, i would try like satin white
gandhi240sx
s13importuner7 wrote:are you doing the door jams and everything? also i have one of those gun holders for spray cans. i like it actually. its kinda silly but its so much easier to use.
not yet. I took off the rear bumper to sand all the edges better so it doesnt peel in the future. I also took off the hood and that is turning out pretty good but that is because i sprayed like 2 heavy coats so... Anyways i'm starting to wet sand the base to get it extra smooth. I found this amazing sanding sponge by 3m,its about the price of a pack of sand paper but lasts a lot longer,and it does wonders when you use it for wet sanding because you dont have to keep dipping it in water as much as regular sandpaper since its a sponge and holds the water. They come in multiple grits, 100 180 and 320. the 180 was the most since it was a bigger sponge but it wasnt to bad. I'll go and take a pic of that hood while its still sunny.Thanks for the positive comments guys
roadboy240sx
Car: I like Nissans
we need more/better pics those dont do the car justice
ZX88
Car: s13
AZ89two4Tsx wrote:Get one of these.
these suck. i was spraying clear and it kept falling off the can and dripping.
JoseBronx
post plenty of good pics when youre done. This bmw is making want to do it also.
SleepyHB
Car: 97 S14
I like the color but just seem like it will b a pita to keep clean.
240daveTX
Car: 2005 Nissan Titan LE
1993 Nissan 240SX Convertible
im pretty sure that beemer has a vinyl wrap
gandhi240sx
Thanks for letting me know cuz i was planning to go get one of those tomorrow. Unfortunatly i cant move the car into a better position to get better pics because my only key broke and i now have to go out and find a locksmith that can replace it
