TurboFortysx wrote:Do the CA's have windage trays? I get quite a bit of oil in my catch can when drifting.
check out crank-scrapers.com
they make crank scrapers (duh) and windage trays... they do KAs, SRs, and L series for nissan, its a future project i have planned to get them to make stuff for CAs ... i addition to keeping oil in a usable state in the sump, as a bonus, it reduces drag on the crank by that same oil/air 'vapor' (dyno gains of a few hp to the wheels) theoretically making it rev-happier in the process
they are very reasonably priced too, ~$100
if somone else wants to tackle this first, be my guest. i just have too many other things on my plate right now
CJ
edit> but yeah, about oil starvation.
you can buy a device called an oil accumulator (i got one on ebay, but dont remember if i never received it, or lost it... cant find it now)
they come in different sizes, but they increase your oil capacity, and hold pressurized oil in a small cell (~1qt was the one i had) then when it senses a loss of pressure, it plumbs in the oil into the pressurized side of the system, restoring the oil pressure and saving your engine.
then when normal pressure is restored, it starts collecting oil again and stores it until next time it detects anything wrong
i think moroso makes them, along with a few other companies (designed for rally and stuff where the car can be tilted to the side, or centripital force causes oil to gather on the side away from the basket
