could anyone (chet, alan, q45 etc.) explain ackermann?
chmercer
ive been reading around about this and its not making a whole lot of sense to me. it is the difference in angle between the front wheels when turned, since the inner and outer wheels will be on a different radius, correct? what effect does modifying this have on steering? any other info?
hannibal
Car: Red Line to Glenmont
I got curious...
Having a high Ackermann factor is useful in taking tight corners at low speed. At higher speeds its usefulness is dubious. In fact, during high-speed cornering the dynamic effects compensate for the Ackermann effect and some even suggested using a negative Ackermann angle, which is sometimes referred to as anti-Ackermann steering. For a racing car, it is common to use zero Ackermann (ie parallel steering).
from this sitehttp://www.mech.uq.edu.au/cour...1.htm
Your definition is correct...
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
My car is equipped with CVAA (Continuously Variable Ackerman Angle) ala loose right tie rod connection with steering rack
Dori Dori
Car: Cars of course
The Ackerman concept is pretty straight forward really. Imagine you're driving around in circles. Your inside wheel would be on a tighter circle than your outside wheel. If your steering used the ackerman steering principles, your inside wheel would be turned at a greater angle...if not, your two front tires would be fighting each other and you'd have a reduction in grip.
Here you go, play with the concept here: http://www.compgoparts.com/tec...n.asp
