could a ........
tony/ka24de
could a o2 sensor cause alot of black smoke. I have checked alot of things and I cant figure out why the engine is smoking so much. Anyone have a solution?
180fan
Car: 89 fastback
yes it's possible but not too likely if it's alot of black smoke.
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
well, My friend brought his 300zx tt to my shop b/c it was running insanely rich with tons of black smoke. We replaced the coolant Temp sensor and the o2 sensor and it was good to go. You might wanna check both of those.
Nismo_Freak
Car: 89 Nissan 240SX
Coolant temp sensor would cause black smoke at any RPM and load.
The 02 is ignored under certain situations, like WOT.
If the engine is smoking all the time then the coolant temp sensor, boost leak, MAF, or the injectors are to blame.
tony/ka24de
the coolant temp sensor that goes to the computer. which is the smaller black one right
tony/ka24de
also i have a s14 rad and if I give my car in the colde(10 deg)my temp gauge starts to drop. therefor the car is getting colder. I have changed the termostate a few times. thats not the problem. Its seems as if the water pump is forcing the coolant through the thermostat.
