This is what I wrote on the Miata forums...BTW, NA = 89-97 Miatas, not Normally Aspirated.
First off, I am a very science/physics oriented person, so while I was bored today at work I thought of something.
How much gas should you run in your tanks if you're going to be racing autox?
I know that has been asked a million times, but read on, maybe this hasn't been brought up before.
I'm trying to see what would be best for your car, running a full or near full tank, or a half full tank. I don't think you can run less than half or else you might run the risk of sucking air into your lines right?
I don't know how big an NA's tank is, but for sake of arguement I will use 12 gallons. Let's say you fill up your tank and go racing. If gas weighs 6.2lbs/gallon, you would have 74.4 lbs of static weight in the rear. You would never have an odd load shift due to a dynamically changing load center, so your left, right transitions would be more consistant correct?
Now if you had a half tank of gas, you'd only have 37.2lbs in the rear, but it would all be dynamic, moving all over the place. Now if you could pull 1G in a turn or in transitions through the sloalams, that gas in the tank would move from side to side at the rate of 9.8m/s (the speed of gravity which is also the lateral rate of acceleration while pulling 1G). Bare with me as I have never taken a hydrodynamics course yet So given that I'll estimate the gas will crash into the opposit wall and settle in 1 second, that gives a force of 365ft.lbs pushing against the side of the tank as opposed to the 74.4ft.lbs of having a full gas tank.
After that 1 second when the gas has settled to either side of the tank, you will only have 37.2lbs of gas to contend with as opposed to the 74.4 for a full tank.
So what's better, a car that wants to get tail happy both upon entering a turn and during transitions but is more planted in the middle of the turn, or one that is more stable at both the beginning of a turn and in transitions but slightly looser everywhere else?
