nismo350gtskyline wrote:I wanna make my 350gt coupe all wheel drive like the sedan? Is this possible or could I use a r34 transmission to make it all wheel drive? Please need help
Swapping to an automatic transmission wont make your G35 all wheel drive. Youd have to swap the drivetrain, and idk much about how that works. I also dont know if it would fit, because the sedan chassis is longer than on the coupe, but again, i dont know how that works.
You would probably be able to use the 6speed transmission from your coupe (assuming thats what you have), in the AWD layout, but ill let sombody who knows more answer this.
Good luck with the swap.
