krash »
https://forums.nicoclub.com/krash-u27755.html
Thu Apr 19, 2012 8:43 am
A lot of people have good things to say about the OEM felpro on their KA-T setups.
If you're going to get a cosworth gasket or cometic or any MLS gasket, you have to make sure that your head and block have the right surface roughness constant. For example, I think cometic requires an RA (roughness average) of 50. Contact cosworth and see what they say.
Cosworth will definitely be a stronger headgasket, but don't overlook the felpro. People have used it for up to 600hp. I personally wouldn't use it for a 600hp KA, but for 400hp, maybe.
One person suggested that using a felpro on an application like that will give you some sort of "fuse". If something is going wrong with your tune or the burn or whatever, you'll likely blow the felpro headgasket instead of something else. Not sure of the validity of this argument, but it makes sense.
