Cosworth Head Gasket 1.5mm vs 1.8mm?
s13_maJiK
Car: s13
I'm looking at getting my head gasket and was looking at the cosworth and noticed that you can get two different thicknesess, what is the big differences between the thicknesess? Does it hold pressure more?1.8mmhttp://www.frsport.com/Coswort....htmland tthe 1.5mmhttp://www.frsport.com/Coswort....html
s13_maJiK
Car: s13
K I found out that the thinner the head gasket the lower the compression, and the thicker the more compression.
Hijacker
Car: '92 240sx Convertible
'94 F-150
You have that backwards
s13_maJiK
Car: s13
you sure? Because if you have a thinner gasket the head sits lower and makes the pistons travel higher into the head thus making there less area for compression, and a thicker gasket makes the head sit higher so the pistion has less travel into the head and has more compression area
hungryjoseph
Car: s13 with rb25 and s13 with s14sr20
compress ion. thicker hg = head sits up higher, bigger volume for compression, which means it doesn't compress as much because the volume is bigger, which means lower compression, you have it completely backwards, what you said makes no sense. and it's volume, not area
Hijacker
'94 F-150
To make a note, the piston does not travel into the head. On our motors, it comes even to the block deck, and then it has a dish in it as well. When you're compressing air, you're taking a cylinder full of air and squeezing it into a smaller space. If you have a thicker headgasket, there's more space to squeeze into, making your ratio less. If your gasket is thinner, there's less space to squeeze into.
Years ago before the magizine really started to suck, Sport Compact Car had a multi-part installment called Suck, Squish, Bang, Blow. The first part of it covers the basics of engine function and how to futz around with aspects of it. You may want to give it a read if you can find it. I believe the first few parts are found in their Engine and Driveline Handbook. Parts 4-7 can be found on their website
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
1.5mm lowers compression .2 over stock. 1.8mm lowers compression .4 over stock.
s13_maJiK
Car: s13
yea my bad your right my I just interpreted stuff wrong, thanks for the fixx
