Costom ram air intake pics
jared
this is my custom ram air
jared
pic2
jared
pic3
jared
pic4
jared
its kind of jank but it works well, the filter is inside the tube of the funnle, i extended the wires for the maf and mounted it to the frame and an intake adapter on the other side, it sounds good down there too.
Slidin240
Car: 89 240sx FB
looks good to be a custom made coldair. Im thinking about making one but imma use PCV piping from Home Depot.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Watch out for puddles, even the smallest one will hydro-lock your engine
[email protected]
Uh huh... have you test driven this yet? i had the same thing but when your driving fast-ish and put the car in neutral it stalls because there is **** loads of air being forced through the maf and making your car run rich. It happend to me on a curvy road and the car stalled and the STEERING WHEEL LOCKED...soo i almost crashed. Not worth it....at all. looks cool tho huh.
jared
i unhooked my negative cable and restet my ecu and after about 20min it drove fine, mabe you had a bad sensor or somthing because this seems to get me through gears quicker and drives completely normal
Someone49
Car: 1992 240sx
hydrolocking you engine isnt worth the small hp gain u prolly get from that
eddiec
Car: 91 S13
i would definitely look for someway to get air to bypass it if you take a big gulp of water.
props for the good idea, just watch the water.
