s14 2510's »
https://forums.nicoclub.com/s14-2510-s-u26808.html
Thu Feb 28, 2008 6:07 am
I got my rb20 1.5 years ago lol. I got engine trans and all wiring ecu... for 1k. Engine had 40k miles real clean inside. Crank work / collar was $260. I took the engine apart my self = free. Block hot tanked, decked, pistons cleaned, girdle cleaned $130. Head cleaned, valve stem seals replaced, exhaust studs replaced with arps, lifters cleaned, head reserfaced and minor other work $230. He also reserfaced a spare lower half of a intake so I could make my forward facing plenum. New nissan gasket kit 140, mls head gasket 160, arp head/main/exhaust 350, calico acl bearings 300. Then you get into buying a new timing belt, tensioner/idler, water pump, crank timing gear, hoses, mounts, and belts. Things start to add up fast in a rebuild. That was just rebuilt in a strong stock form. Pistons are going to set you back 600 + bore and hone. Then your still running stock turbo injectors ecu..... The list keeps going on if you do it right.Theses are just average prices I chose not to remeber what I actualy spend on my rb's it scares me.
