cost of vvt solenoid
MikeDombeck
Car: 1995 Nissan 240sx SE S15 SR20DET
how much do they usually run for, someone quoted me at 175 but that seems a little steep.
bgsr240
Car: 90 240sx hatch sr20det redtop gt28rs-sold 89 240sx hatch S14 sr20det blacktop
I wouldnt even bother with buying a new selenoid and just put that money toward a set of cams. More power potentail in the long run...
MikeDombeck
well, my car is not running right, and ive herd that it could be the vvt going bad. so, what good is new cams if the car isnt running right, are cams gonna disable my vvt
SpeedRacer1
Car: 1990 240SX, G35
A bad VTC solenoid will not cause a car to not run...
bgsr240
You should be able to unplug the selenoid and it will run just the same, check all your other sensors. You are going to have to be more specific about what is going on with it for more help. I'm not sure if you can swap cams and keep the VVT or not but most people just get rid of it. But I know that the power you will get from cams with more duration and lift will far exceed what you get from the VVT(low end torque).
battleroyale
it should be around 65 bucks for the vvt selonoid
