5-7k for jus the turbo, or the whole engine, and does it come with ecu, trans, and such??sultan wrote:a couple japanese companies make them. i think top secret has a single turbo manifold and blitz has a 1999 skyline with a single turbo conversion (search for blitz skyline, there's many articles about the car). the ones i've seen are at least 5-7k for single turbo kits.
nlzmo400r wrote:damn, anyone know how much an RB26dett might cost for the engine, trans, ecu, harnesses and mounts, and to get it legalized
well its obviously more than i have, haha, but i dont see why u couldnt use an rb26dett transmission, i didnt mean neccesarily for a 240, but for anything, and i know legalization of a skyline is an easy 20gs, but i was jus curiuosJ-Spec Tuner wrote:more than you have. first off, you cant use the rb26dett transmission, so you have to buy a rb25 transmission, the ecu would come with it, and you dont just get the mounts, you need a whole crossmember (a31 i think, and others). it that alone would requir quite a bit of finnessing to get into a 240. plus it would cost you $6K or more for just the engine set
EDIT: o yeah you can NOT get it legalized unless you go though MotoRex. and that is really really expensive.
true, im jus thinking of pricing on one, that is a lot of money, but imj sure someone will fit it into something, hell, have u ever seen a NRX, take a guess, yes, its a CRX, with an NSX engine, so i figure if they can pull that **** off, im sure someone could stuff an RB into somethingJ-Spec Tuner wrote:well, unless you want to spend another $6k making your 240sx AWD you can use the rb26dett transmission (because its AWD only :rolleyes )
