Cost of Bushing Replacement
sublime187
Car: 2000 Q45 Anniversary Edition 101k
My car is very "creaky" when stopping and subsequently starting to move again. You all say that these are bad bushings. Can anyone tell me how much this generally costs to fix as far as parts and labor are concerned? Any recommendations?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Call Joe and his guys at
http://www.infinitipartsusa.com
Could be link bushings, tension rod bushings, front strut bearings.
What suspension maintenance have you performed?
sublime187
No suspension maintenance has been performed. To be more clear about the symptoms. as soon as I pop it into to reverse pulling out of the driveway, as soon as I release the brake, "CREEEEEAK". Apply the brake, "creak." Pop into drive, release brake "creak." These are the only times the noise is apparent. I hope this make sense...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You don't mention miles or if it is driven in salt.
Time to read the posts here and determine your course of action and timing.
I would encourage you to keep the OEM electronically controlled shocks regardless if you change the springs or not.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
I've got a 99 with the same noise but my sound is like a small spring being dinged but it occurs under similar conditions, changing directions from forward to backward and vice versa.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Sometimes brakes creak. Does it seem like it happens when you're lightly on the brakes?
sublime187
It's definitely not the brakes. The noise comes from when the car settles, after the braking. The brakes are hit, the wheels stop, and when the body settles into place THERE is the noise, and again when the car is back in motion.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Might want to add spring seats to that list.
sublime187
I had a mechanic check out my suspension a few days ago. He said the noise was coming from the subframe bushings. Despite how noisy they were, he said they were OK and didn't really NEED to be replaced, they were just brittle. I asked him if I could try some lubricant on them to quiet them down and he applied some motor oil. Well the noise is totally gone now. I'm going to have him apply some white lithium grease as I've heard this may be a better solution.... I'm preparing for the shred... Cue Maxnix.
As a side note, I had an annoying rubbing/wah-wah noise coming from the front tire area, and upon inspection all components were fine. A tire change and alignment later, problem is gone.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Probably slilght cupping on the inside of the tire caused the latter phenomena. Track your tire behavior and contribute to the sticky thread in Infiniti General as it is a great resource that is specific to these large sedans.
Motor oil is not the best thing for rubber. Something like Wurth preservative is. Brittle ness is an immediate prelude to failure. Keep an eye on it for leaks of the viscous fluid. Very visible if inspected every OCI.
96Qowner
Car: 1996 Q45
You do NOT want to have to replace the subframe bushings - difficult and spendy. Take Maxnix's advice and get some Wurth's. Baby 'em as long as you can.
Here's a recent thread with some embedded links to old threads. Unfortunately the pics are gone.
zerothread?id=275433
You have to pull the subframe and the entire rear suspension to get at the bushings.
sublime187
wow. a bottle of 303 aerospace on them just before thanksgiving and 6 weeks later, still no squeaking from my bushings! and they were NOISY before. i'm gonna buy a new bottle of the stuff and take a shot of it once every 6 months. better to spend the $15 now on preventive maintenance than the alternative.
96Qowner
Car: 1996 Q45
