Q45Viper »
https://forums.nicoclub.com/q45viper-u6953.html
Wed Jul 09, 2003 7:01 pm
You need to be very specific regarding the list of parts. If you have searched this site you may still have the wrong list as many posts started with a list and were corrected by the experts. The most accurate way is to CALL Joe at Scottsdale Infiniti, have him fax you the parts list and prices. Then start calling dealers and talk to service managers about their expertise to do this, ask them if they will allow you to provide the parts or will they MATCH the price, be sure you are talking about the same list of parts. Next find out how many hours are being quoted and at what hourly rate. Next, and very important, find out if they are quoting you based on dropping the pan, which only needs to be done if the chain is broken and the pieces have dropped down. That second stage alone adds $600 approx. You've got to shop this job around to get the best deal, I'm an original owner who had been very happy with my selling dealer till this deal came up. It took a lot of calling and researching but I finally found a dealer at a reasonable price and with expertise. I paid a little over $2000 including oil change and no pan drop. I did NOT try and squeeze the last dollar out. Regarding some of the other issues, don't get too frightened yet as to all the costs need to bring this car up to spec. What you HAVE to do is make a diagnosis of exactly what is needed. The absolute first thing is to have a dealer run the VIN number for a service history, you may be pleasantly surprised. Some of the potential problems....Transmission, I would be willing to bet a significant amount that this is not the original tranny, it's probably been fixed and has the cooling upgrade, for safety you will need to do the complete flush and pan drop and filter procedure, that will solve your second biggest risk after the chains. I bet the radiator is not original either, many times they get damaged by tranny failure, mine was. The AC is another big expense when it goes, but again I bet if it blows cold now it's already been replaced. Yes, you will have to do under the plenum, all the hoses, knock sensor and injectors at some point, but again you are flying blind, how do you know a lot of this stuff has not been done? you really need to find out the history of the car, do you have any service records? Can you get them from the previous owner? Have to ask nicely without indicating there is a problem. Do an analysis on what is actually needed before making a decsion, a lot of this stuff can be budgeted if it's running ok, you can limp along a little before doing the suspension and if it's running ok you don't need to be under the plenum just yet. One common thing here, you keep saying it looks great. Good paint no dings? Good interior, clean, no rips in the seats. If it LOOKS that good it has probably been maintained well. Call this dealer you've been to, have him run the service history, that's your first step.
