S13FX »
https://forums.nicoclub.com/s13fx-u28329.html
Tue Apr 25, 2006 10:04 am
Here is what I did for power on my gauges.
I bought my self a nice battery terminal and some black and red electrical wire, and Im runing all my guages straight from the battery on a power switch.
I also put a fuse half way through the power wire that goes from battery to the switch. Now this is a good easy way to do it only if you dont mind having your light bulb on at all times. I put my red light bulb sleeve on, so during the day you cant even notice the light on and once it starts getting darker the light is already on, with this setup you also have to renember to turn your gauges off, not like they will drain the battery over night or anything but still. Hope that helps.
