amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Wed Aug 07, 2019 9:30 am
Again just for you.........
'Even if tight, the finish alone inside the groove can cause them to not seal if rough enough to not allow the ring to seal right.'
AND........a physically bigger OD ring is NOT what I'm talking about there, that could be the worst thing you do. Bigger THICKNESS or cross-section instead if cut in two by a razor blade, but still smaller ring like the other.
Stiffer rubber will seal worse in an imperfect groove too. A/C rings are green in color.
Even a correct ring can leak if not lubed to then roll part of the ring over while the rest does not, or it picks up mini-scratches from friction due to no lube. A/C will go right past that.
I have even made my own by installing on a straight piece of steel line with a groove in it, spin it in a drill and lightly sand the OD down using #1000 or finer sandpaper.
I have never had trouble at all ever on sealing o-rings up once I got dead serious about it.
I'd even bet I can refinish/polish the grooves and outer tube to be smoother, food for a future day as I have never done it but with 2-3 ideas in my head how to do that too. Something there will work as there is no reason why it won't. Life in my world outside the box, I don't accept never. There is no rocket science there at all.
