S13FASTBACKSR wrote:to test the voltage you take the needle of the red wire ( on your volt meter, the positive) and poke it into the wire of the maf..the needle of the black wire on your volt meter you touch to a ground...something metal..if you get no reading try a different ground
do you mean the actual maf filament itself or just the wires that connect to the maf? i assume you mean the wires that run to the maf...
i also have to cut the rubber insulation and expose the wires correct?
thanks guys you have been a real help. i'll post my readings
Modified by Deadrodent at 12:39 AM 1/14/2007
