biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Wed Feb 25, 2004 6:37 am
OK, so this has had me wondering, since I'll soon be getting a CA myself finally..
I searched up the #'s for the S13 CA18DET from the UK Nissan FAST parts catalog and the KN13 CA18DE from the US Nissan FAST (KN13 = pulsar). I can't check Japanese FAST, I got a corrupt B1 disc which has the S13 stuff on it (argh!) so can't double check that.
(alt = alternate #, aps = alternate parts search, which is if you do a APS on the part to see ALL not just first aps, only listed the #'s not already listed as alternate)(partsmaster is a part of FAST that can search all the models on CD(s) and list all that use a given part#. it pwns!)
part#'s from FAST:
UK S13:21010-V5529 alt 21010-50V25 aps 21010-50VY5
US Pulsar NX:0887-0289 21010-06E25 alt 21010-06E26
0289-0989 21010-06E26 alt BA010-06E26
searching for these parts in parts master:UK partsmaster:21010-V5529 used in: CA18ET (S12, 1087- ) CA18DET (S13, 0988- )
21010-50V25 not used in anything21010-50VY5 not used in anything21010-06E25 too many to list specifics.. basicly all CA FWD variants B12 CA16DE, CA18DE M10 CA20S, CA18S M11 CA20E, CA20S N13 CA16DE, CA18DE T12 CA16S, CA18DE, CA20E, CA20S, CA18DET T72 CA18DET, CA20S, CA20E, CA18DE, CA16S U11 CA20E, CA20S21010-06E26 too many also, basicly the same cars/motors as 21010-06E25 but as a replacement part and also for later years of same cars BA010-06E26 shows up as APS via parts master for the FWD motors also, but doesn't actually list as being used when searching by the # itself
US partsmaster:21010-V5529 used in:CA16DE (KN13, 0986-1086)CA18ET (S12, 1087- )CA20E (S12, 1087- )21010-50V25 and 21010-50VY5 show up in APS via parts master for 21010-V5529
21010-06E25 used in:CA18DE (KN13, 0887-0289)CA16DE (KN13, 1086-0887)CA20E (T12, 0786-0289)
21010-06E26 used in:CA18DE (KN13, 0289-0989)CA20E (M10, 0786- )CA20E (T12, 0289- )
BA010-06E26 not used in anything when searching by the # itself
----------------------OK, so this would incate that RWD CA18ET and RWD CA18DET have the same design for water pumps, in fact at least originally they are identical. often times when alternate #'s have charachters instead of #'s in the XXAXX (where A is normally a letter, XX is normally #'s) that indicates a locally supplied part (i.e. built "locally" rather than in japan or wherever the original parts are sourced, hence why often replacement parts have alternate #'s for the local supply, you see this w/ oil filters for example)
Furthermore, it would indicate, at least with ORIGINAL PARTS *NOT* ALTERNATE that FWD and RWD are interchangable. However, if the aftermarket/rebuilt pump is made to FWD alternate / local spec it wouldn't necessarily be suitable for RWD as many have pointed out problems. Someone might want to look for a pump for a CA18ET next time they need one and compare if it has the C clip etc that seems to be the important difference..
wheee, thats alot of crap.(edit: correction of uncertainty of corrupt Japanese FAST disc, being more specific about "all CA" vs "all FWD CA" in the partsmaster UK section, being more specific about BA...-..... part#)
