a_ahmed »
https://forums.nicoclub.com/a-ahmed-u40386.html
Fri Sep 21, 2007 1:00 pm
what i did as i can not afford swaybars or better springs+shocks at the moment plus i plan to park the car for winter is run lower tire pressures in rear and higher in front... its a patch fix but alas.
I am running 3/4 front and 7/8 rear on the agx with stech springs... it does not understeer.. as it used to... almost every other setting understeered...
I want new swaybars.. and coilovers, but before i go that route the car will sleep for the winer (very soon )... I'm in canada ey lol..
Oh yeah installing rear strut bar helped me get rid of understeer too is what i noticed.. but once i installed front strutbar and nismo power brace i introduced understeer again (although the car did have better turn in and was much more tight in feel).
i have all whiteline bushings... except that the subframe inserts SNAPPED (gay), but its too much work for the time being to get spl solid aluminum ones....
i have spl pro outer + z32 inner tie rods and tc rod are on the way, wont get rid of understeer but im sure itll improve feel and turn in... and well i kind of want to get that c pillar bar to tighten rear some more... i will see what that does, hopefully itll have an effect on eliminating understeer as the strut bar did (i could notice a big difference).
My next purchase is a custom coilover setup and sways... that wont happen until next spring/summer...
Overall though what i have now is a descent setup... needs more grip and less understeer, and i want more response/turn in...
Unfortunately I won't be able to run more autox as the season is pretty much over... it will probably start snowing here anyways haha... I miss the summer already
