Correct wheel offset for 92Q?
Q45Viper
Can anyone tell me the correct offset for a 92Q wheel?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
44mm sounds right to me....... Im not sure though....... I just ask people here if they will fit...... :)
szh
Car: 2018 Tesla Model 3.
45mm was the standard for the 15x6.5 rims.
Z
Q45Viper
So a 17x7 with 45mm offset should be an exact fit also?
szh
Q45Viper wrote:So a 17x7 with 45mm offset should be an exact fit also?
It should work, but you should check it out carefully. As long as you do not go crazy on the tire width. FWIW, the 7" rim limits you to use something less wide than 245/45-17's - see my list of tires for a Q in another recent post.
35 and 40mm offsets also ought to work. I used G35 Coupe wheels at 17x8 and 17x7.5 with 30 and 33mm offsets on a Q. These were farther out than the 45mm wheels, and I was a bit concerned about fender rubbing, but it seemed to be okay.
Z
