Correct Specs for the 1999 R-34 GT-R v-spec
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
Attila_S2C
I need to make sure with out a shadow of a doubt that these specs are correct. Thanks.
engine: Water Cooled RB26DETT Inline 6 position: Front Longitudinal aspiration: Twin Turbo valvetrain: Belt Driven DOHC 4 valves / cyl displacement: 2568 cc / 156.7 cu in bore: 86.0 mm / 3.39 in stroke: 73.3 mm / 2.89 in compression: 8.5:1 power: 205.8 kw / 276.0 bhp @ 6800 rpm hp per litre: 107.48 bhp per litre torque: 293.0 nm / 216.1 ft lbs @ 4400 rpm redline: 8000 drive wheels: Full Time 4WD front tires: 245/40W18 rear tires: 245/40W18 front brakes: Brembro Vented Discs w/4-Pot Calipers, Vacuum Assist & ABS f brake size: 324 mm / 12.8 in rear brakes: Brembro Vented Discs w/2-Pot Calipers, Vacuum Assist & ABS r brake size: 300 mm / 11.8 in front wheels: F 45.7 x 22.9 cm / 18.0 x 9.0 in rear wheels: R 45.7 x 22.9 cm / 18.0 x 9.0 in front tire size: 245/40W18 rear tire size: 245/40W18 steering: Rack & Pinion w/Speed Sensitive Power Assist f suspension: MacPherson Struts w/Addional Link, Lower A-Arms, Coil Springs, r suspension: Mulitlink Setup w/Coil Springs, Tube Shocks, Anti-Roll Bar weight: 1666 kg / 3673 lbs wheelbase: 2665 mm / 104.9 in front track: 1480 mm / 58.3 in rear track: 1490 mm / 58.7 in length: 4600 mm / 181.1 in width: 1785 mm / 70.3 in height: 1360 mm / 53.5 in transmission: Getrag 6-Speed Manual gear ratios: 3.827:1, 2.360:1, 1.685:1, 1.312:1, 1.000:1, 0.793:1 final drive: 3.545:1 top speed: 249.4 kph / 155.0 mph 0 - 60 mph: 5.2 seconds 0 - 100 mph: 13.0 seconds 0 - 1/4 mile: 13.7 seconds
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
The only discrepency that I know of is that the GT-R was not full time 4WD. The ATTESA-ETS system would only engage the front differential when it discovered that the rear wheels were slipping.
Return to “GTR Forum / Skyline Forum”
