Correct Key Fob for CwtwC1u241
raj49
Hi. tried searching but didnt find clear answers.
1. I found the Keyless receiver behind glove box with FCC ID CWTWC1U241 but dont know the correct Key FOB for it. Im assuming its the same one for CWTWB1U415. Is that right?
2. I also lost the key that operated the ignition. But I have a key that opens the door but wont turn the ignition. Any cheap replacement options?
I know I'll have to get key made before doing key fob.
Appreciate any help.
raj49
Anyone? Did I post this in the right Sub forum?
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
Is this for a Versa with keyless ignition? If so, I imagine they'd both have to be made together, with no cheap option. If not, then even the key won't be cheap, because the keys have an RFID chip inside for the car to recognize them, and even a key that fits perfectly won't start the car without the chip. I hate to say it, but either way it sounds like you need to go to a Nissan dealer and talk to them about your options.
raj49
Thanks for the reply.
I actually have regular transponder key, not the Proximity key. Got the key cut at dealer and programmed by locksmith. Locksmith needs the pin/keycode to program the key which they can get themselves for extra charge but I got it from dealer after providing them the BCM serial number.
kc5f
2012 Nissan Versa
2016 Nissan Juke.
The second post on this thread makes it sound like the key they cut for you was cut right but may not have been chipped/programmed correctly:
spare-key-t582027.html
