Correct Alarm / Remote Start Wiring for 97 QX4
GFinger
Car: '97 QX4 (sold)
'03 QX4
I have recently installed a Remote Start system in my 97 QX4 using the wiring information that I found on-line on a few sites. This info is partially INCORRECT. The door lock wires are backwards, the door trigger is incorrect, and there are a number of other mistakes. If you are planning on having an alarm installed, I suggest you bring this to the shop that will be installing the alarm.
I got this information from the factory service manual for my 97 QX4, and I don't know wat other vehicles this is accurate for. I spent a few hours searching through various sections of the electrical portion of the manual and looking at many schematics to map out the correct wiring. I have verified that these are correct. There are some wires that are not needed, but I included them anyway. There is no need for a key module since there is no chip in the key. If you are installing a remote start alarm, the factory dis-arm is required. For added security, you can connect the factory re-arm to the alarm as well. anything with a NR denotes the need to use a relay. SEU is the factory security module and the number in () is the pin number. This is useful as there are repeats of some of the wire colors like yellow/green for the headlights.
1997 Infiniti QX4 Remote Start Wiring Part Color Location12V Constant - White/Purple (+) - Steering Column HarnessStarter - Black/Yellow (+) - Steering Column HarnessStarter 2 - Red/Blue (+) - Steering Column HarnessIgnition 1 - Black/White (+) - Steering Column HarnessIgnition 2 - Red/Yellow (+) - Steering Column HarnessAccessory - White/Blue (+) - Steering Column HarnessKeysense - White/Red (-) - SEU(24)keysense is not needed to start this vehicle.Parking Lights - Pink/Blue (+, NR) - Steering Column HarnessSignal Lights (hazards) - Pink (-) - SEU(7)Power Unlock - Light Green/Red (-) - SEU(19)Power Lock - Brown (-) - SEU(18)All Door Trigger - Red/Blue (-) - SEU(16)This is for all 4 doors and the hatch.Driver Door Only Trigger - Green/Red (-) - SEU(15)Passenger Door Only Trigger - Yellow (-) - SEU(35)Dome Supervision - Red/Black (-) - SEU(9)Glass Trigger - Blue/White (-) - SEU(26)Hood Trigger - Yellow/Blue (-) - SEU(29)Hatch Release - Lt Green/Red (+ NR) - Hatch Release SwitchBrake - Green/Yellow (+) - Driver's KickpanelFactory Disarm - Light Green (-) - SEU(31)Factory Arm - Yellow (-) - SEU(30)The factory arm and dis-arm are actually the wires that are connected to the driver's door key cylinder. when you use the key to unlock, it sends the dis-arm signal, and lock sends the arm signal.Defroster - Orange (- pulse toggles) - SEU(20)Tach - Blue - DistributorHorn/Headlight Flash - Yellow/Green (-) - SEU(8)This wire activates the Horn and the High-Beams at the same time.
This is a FYI, not a guide to install an alarm. If you don't know what all of this means, I suggest that you don't attempt to install an alarm yourself.
Modified by GFinger at 10:32 PM 5/11/2009
GFinger
Car: '97 QX4 (sold)
'03 QX4
Sorry, for some reason in the preview it was all nice in a table format, after posted its all run together.
NocturnalQX4
Where is the SEU Located? do you have a pic?
