RB20's weigh less, and the transmission weighs considerably less.zauber wrote:does the rb20 weigh less than the rb25?i am swapping rb20det into my 91 nissan 240sx se coupe. thank you for the post because i have been thinking about for some time, and i thought it would be a larger issue with weight.
No, water passages are different. Remember you can't bore a 20 block to the 25's diameter.Sil240 wrote:I thought that the block was the same but it just had the smaller transmission(RB20)
This is wrong. According to simple physics principles, any weight removed ANYWHERE forward of the car's center of mass or any weight added behind the car's center of mass will reduce the front sprung weight and increase the rear sprung weight. There is some truth in your statement though, the farther forward the weight is removed from, the more drastic the weight shift will be.Bluefire wrote:Well basically using the front strut tower bar as a reference point, anything in front of it is what affects the front to rear ratio. And same thing for the rear, anything behind the trunk strut tower bar will affect the ratio. So even though you may lose like 30lbs by switching to cf or glass, you really only losing like 15lbs since half of the weight is behind the front wheels. Samething with heavier wheels. It won't do anything front the front to rear weights.
You want to focus on items before the front tires(Headlights, Front Bumper, Bumper Support, Battery, Radiator, Intercooler) and behind the rear tires
-Bluefire
ExactlyWulfgang wrote:I don't want to kick a dead horse, but it's really a question of moments (weight x distance from CG). So using that, if your FMIC goes on a Slimfast diet and loses 18 lbs (assuming it's 6 feet from CG), then a 200 lb driver could get the same effect on the F/R ratio by sliding his seat back 6 inches.
And btw, you can't discount the fact that the cf hood saves 30 lbs. That means your car is 30 lbs lighter and will now have more than 1% more acceleration. (However, my OEM hood can't be over 30 lbs, so unless the cf hood weighs zero that number is inflated.)
