When you change to LED bulbs, if there isn't a resistor built in you need to get one or else the system thinks its a dead/near dead bulb which makes it blink really fast to let you know to change it.joe603 wrote:I dont think resistors would make a difference in how fast a bulb blinks...only how bright it is.
if u put a resistor to replace oem bulb u will have troubles... so in fact, led bulbs dont need to much current. do this:LongBeachCoupe wrote:
i want to change the corner signal bulb... As a result because of the lower power, it will cause a fast blink...
What i am trying to figure out is what type of resistor i need to get to make it blink regular speed, and where can i get them..
Thanks!LBC
u have good points, but the truth is resistance lower when theyre conected parallel, but the resistance of the led plus the resistance it need to conect its high, so the total resistance will be droped a little, something insignificant.C-Kwik wrote:Resistance does go up with heat, yes, but it's likely, that in a bulb, the resistance would increase to the peak very quickly (or close to). At that, the current draw at the lower resistance periods would be higher. And as all flashers that I've worked with seem to work with different levels of resistance just fine, I don't anticipate there would be any problems that would occur from this small amount of variable resistance. But if you know something I don't, then please share. But you do bring up an important point. It may be necessary to compensate for ramp up in resistance that occurs with each blink. Perhaps if the flasher somehow uses resistance and/or current to regulate the flashing, then some average value might be needed.
As for running the bulb parallel, if resistance is an important factor, than I would recommend against it. Mainly for the fact that running it in parallel would lower the overall resistance down to a level that is lower than the LED by itself. But without a resistor, it would likely burn up the LED anyways. Not entirely sure if running it in series would be a good idea either as it would have to pass the same current as the bulb.
Did a quick search and found an easy to understand site about LED's. This may help the original poster a great deal:
http://www.kpsec.freeuk.com/components/led.htm
thats its the porpuse of keeping bulb conected !! a bulb is cheaper than a big watt resistor.want2turbo wrote:New here, but thought I would throw in my two cents.
To make a really long explanation short, the resistance of the light bulb is used to set the blink rate along with a capacitor, (RC time constant)
Resistors in parallel will always calculate to be lower than the lowest resistor, basically more resistors in parallel = less resistance
In series they will simply add up.
To get resistors, is there a Radio Shack in your area? Or maybe a hobby shop, RC kinda place?
I bet they are cheaper than those in the link, you will need to know the resistance and wattage to buy them, if in doubt, go with a higher than expected wattage rating. They will probably get hot.
